create cfm segment segment_name destination mac_addr {copy segment_name_to_copy}
delete cfm segment [segment_name | all]
configure cfm segment segment_name add domain domain_name association association_name
configure cfm segment segment_name delete domain association
configure cfm segment segment_name {frame-delay | frame-loss} transmit-interval interval
The same transmit-interval is used for both delay and loss measurements.
configure cfm segment frame-delay/frame-loss transmit interval interval
configure cfm segment segment_name frame-delay dot1p dot1p_priority
configure cfm segment segment_name frame-loss dot1p dot1p_priority
configure cfm segment segment_name dot1p dot1p_priority
The same priority is used for both delay and loss measurements.
configure cfm segment segment_name [alarm-threshold | clear-threshold] value
configure cfm segment segment_name window size
The same window size is used for both delay and loss measurements.
configure cfm segment segment_name frame-loss window window_size
configure cfm segment segment_name frame-delay window window_size
enable cfm segment frame-delay measurement segment_name mep mep_id [continuous | count ] value
disable cfm segment frame-delay measurement segment_name mep mep_id
show cfm segment {segment_name}
show cfm segment frame-delay {segment_name]}
show cfm segment frame-loss {segment_name]}
show cfm segment frame-delay statistics {segment-name}
configure cfm segment segment_name timeout msec
configure cfm segment segment_name frame-loss [add|delete] mep mep_id
configure cfm segment segment_name frame-loss ses-threshold percent
configure cfm segment segment_name frame-loss consecutive frames
enable cfm segment frame-loss measurement segment_name mep mep_id [continuous | count frames]
For the above command, If the the segment is not completely configured, frames are not transmitted and an error occurs.
disable cfm segment frame-loss measurement segment_name mep mep_id
Frame-loss measurements are not supported on platforms where the VLAN packet statistics are not retrieved, and on up-meps.
